Alcatel Pixi 3, and some other similar/related phones
-- There is a common fault with the charging docks. Although the dock is supposed to be superior to the USB/charging plug, these phones have poor quality docks. The idea is, after repeated use the weaker component will fail first. In many cases the weaker componant is unfortunately not a cheap cable that nobody would mind replacing.
-- there are also 2 other very common issues. One is with the ribbon feed wires from the battery to board. It's not uncommon for the small plug to work loose, (through phone movement/vibration, heating, etc), creating a poor enough connection you can experience a number of issues, most commonly:
Without warning the phone may simply power off and fail start. If left for a while it may fully start and last a few hours, or it may power off just half way through the first boot. Typically, if it doesn't last through the boot-up this time then it won't make it much further than the first vibrate next time round.
++ To solve this, remove all the tiny screws and remove the battery. Inspect the connections and manipulate the connection rods very slightly in such a way to create a more rigid hold once the plug is returned. A drop of an epoxy, or non-conductive super glue on top of the fixing should prevent this repeating.
-- Another problem, a little less common yet with similar symptoms is again a circuitry connection issue. By t
Yeah, I came to this website to find out how much it costs to get my phone fixed because i had this same problem. Accept for the fact that with my charger, there were a few of the things that were inside that connected the charger and the phone together so therefore it could charge, a few of those were missing.
- de Lupe Runnels
just try to upgrade it using one touch upgrade s 2.8.0
- de kifuhowe
I got my phone yesterday and it stoped working I charged it and took the battery out and put the battery in and it wouldn't work
- de Kydyn Gaitan
Same though my phone was not in the charger, it was on 48% , but when i woke up it didnt want to turn on i tried putting it in the charger, i tried putting a pin in that hole and still wouldnt work.
- de Ruqayah
I have two problems with mine. I put it on the charger and I have to bend the charger to the side so it will charge. and my phone keep freezing and shutting off. but when it it freezes i take out the battery and out it back and its fine. but it does this at least 3 times a day. I don't know what is wrong with it. or how to fix it.
- de Jay Hope
Mostrar 34 comentarios más
