Asus K52F has an error screen, how do I fix it?
The error screen says:
to your computer.
DRIVER_IRQL_NOT_LESS_OR_EQUAL
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use a safe mode to remove or disable components, restart your computer, press F8 to select advanced startup options, and then select safe mode.
Technical information:
- STOP: 0x000000D1 (0x0000000000000004,0x0000000000000002,0x0000000000000000,0xFFFFF8800AA1DBD4)
*** athrx.sys - Address FFFFF8800AA1DBD4 base at FFFFF8800AA01000,Datestamp 4b8db121
This isn't the first time it has popped up, but this time we can't get rid of it.
Es esta una buena pregunta?
