Saltar al contenido principal
The HP G71 is a laptop series produced by HP. G71 laptops are identifiable by the model number G71-XXX-XX, and endings vary depending on options and seller.
Preguntas 8 Ver todo
Pregunta Cerrada
replacing the HDD with an SSD
Is it possible to replace the HDD with an SSD on my HP G71?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Yes you can.
You'll get some performance improvement after SSD replacement as the systems CPU & memory will limit you. You will gain more run time using the laptop in battery mode, than running with a HDD.
Modern SSD's come with auto sensing SATA III (6.0 Gb/s) interfaces. Your systems chip set only supports SATA I (1.5 Gb/s). The SSD will sense this and run at SATA I (1.5 Gb/s) speed.
Fue útil esta respuesta?
Puntuación 3
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 780
