All-in-one printer and scanner.
Preguntas 9 Ver todo
Instructions for dismantling the printer.
Need help or instruction for dismantling the printer. He fell into a small object, and does not feed paper.Stef
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Agregar un comentario
2 Respuestas
Respuesta Más Útil
https://www.youtube.com/watch?v=yGnRWUL7...
Fue útil esta respuesta?
Calificación 2
Comentarios:
Thanks for the link this is very helpful!☺
por
Follow The Steps to Dismantling the printer
Step 1: Lift up the Deskjet's top plastic cover and wait for the ink cartridge carriage to slide out from the left side. Pull up the two ink cartridge covers and remove the ink cartridges.
Step 2: Leave the top cover open and unplug the Desk-jet's power cable. Disconnect the USB cable. Locate the four locking screws on the top-left and top-right sides of the Desk-jet.
Step 3: Remove the screws with a hex screwdriver and pull the top half of the case off the Desk-jet printer. Remove the screw on the left side of the button control panel and pull the panel off the printer.
Step 4: Locate the thin, green plastic ink absorbed at the bottom of the printer's case. Pull the absorbed toward you and lift it out of the Desk-jet.
Step 5: Remove the screw holding the printed circuit board in place at the right end of the Desk-jet. Pull the circuit board out of the printer.
Step 6: Remove the screws at the left and right ends of the ink carriage and pull the carriage out of the printer. Turn the printer around so the back end is facing you.
Step 7: Push in the visible plastic latches and pull apart the top and bottom halves of the plastic casing and finish disassembling the HP Desk-jet printer.
Calificación 0
Añadir tu respuesta
stefan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 7
Últimos 30 Días: 43
Todo El Tiempo: 1,152
