Xiaomi Mi3 es un smartphone Android de gama alta fabricado por Xiaomi.
Preguntas 26 Ver todo
No service (out of service) after touch screen replaced successfully
Hi,
I have replaced successfully the touch screen as per the instruction given. Now mobile is working perfectly but unfortunately there is no signal. so not able to make calls and changed SIM cards for my satisfaction. I have done flashing with latest ROM available in MIUI website, but nothing works.
Please help me to fix the problem.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Agregar un comentario
5 Respuestas
Respuesta Más Útil
Check the antenna contacts. if you can update snapshots of status, i would happy to help you
Fue útil esta respuesta?
Calificación 1
Comentarios:
Hi,
Thanks a lot for immediate response.
Actually the antenna cable terminal came out from wire at Mother board end, but some how I connected.
That could be the problem for this right?
I have screen shot but not able to paste it here.
por
use low impedance cable and they shroud be short as possible only if you connect antennas manually because it is stable high frequency connectivity such as 1800 Mhz 2100Mhz. Cheers!
por
Thanks a lot.
por
how do i solve this issue ..please help ..recently replaced my screen and now it shows no service.!..PLEASE HELPP!!!
por
Please help me to solve this issue. i got screen replaced for my xiaomi mi4i. Network reception has become very poor
por
Mostrar 3 comentarios más
Hi
Please hlep to check if these have one GSM Signal antenna has been assemble well.
Thanks
Jack.
Calificación 1
With Xiaomi Mi4 also not work after replacing lcd and touch screen :(
Calificación 0
Comentarios:
my mi4 display replaced but it shows mi logo after screen goes black help me plzzz
por
@husna Did u solved it? Try flash to stock rom, if it doesnt fix then maybe ur eMmc prob.
por
Hi,
i also got my screen replaced for my Mi4i. network connectivity is very poor now.
Please help me to correct it. i dont know which part is the antenna.
Rishab
Calificación 0
Comentarios:
Hii, good evening everyone, my Xiaomi redmi note 3, just fell faced down and shattered. I am in Lagos, please where can I repair it and is it advisable to repair. So I do not end up with more problems, can I just put screen protector to cover the shattered face since it still works(the touchscreen). Thanks.
por
1500 screen buy from ebay and replace
por
Did u fix this? Recently i also replace my broken lcd screen. Same issues as u guys, no network after replacement. Now i regret i replaced the screen by myself.LCD works fine, but i dnt what goes wrong with no service and sometimes super pooor network.
por
My Mi 4i screen is broken and part of the touch is not working..also the network drops many times and coverage is very less... Is this because of the cracked screen? Please help!
Calificación 0
Añadir tu respuesta
kannasen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 23
Últimos 30 Días: 128
Todo El Tiempo: 8,129
