Saltar al contenido principal
Lanzado el 21 de julio de 2011. Procesador Core i5 o Core i7. Rayo. Esta unidad también se utiliza para ejecutar la configuración de Mac mini Server.
Preguntas 204 Ver todo
Pregunta Cerrada
Install a second HD
Does a Mac Mini (Mid-2011) have the space/capacity to install a second HD, specifically a 1 TB SSD. Leaving the existing factory installed HD in place?
If so will the Mac OS support the second internal drive?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Yes! Very doable!
I have two 2TB drives in my home system as a media server. I put both in.
Here's the IFIXIT guide: Installing Mac Mini Mid 2011 Dual Hard Drive Kit, Here's the kit: Mac Mini Dual Drive Kit which will give you all of the pieces.
As for the drive, all you need to make sure of is the hight of the drive does not exceeds 9.5 mm and is a SATA III (6.0 Gb/s) drive. If you can swing it I would recommend getting a Seagate SSHD drive Vs a standard drive. Hybrid drives offer deeper caching which speeds up the boot up and launching of apps. Heres a link to the Seagate page that talks about it: Laptop SSHD.
Imagen de Mac mini Dual Drive Kit
Producto
$26.99
Fue útil esta respuesta?
Puntuación 2
8 comentarios:
Thank you very much for the clear answer and the included link. I greatly appreciate your response!
One last question as I'm new to the Mac world. Once I install the second HD (Yes, I plan to install a SSD), do I have to make any BIOS type changes like I would with a PC?
- de
A 1TB SSD is quite expensive! If you go with a 1 TB SSHD (hybrid drive) you can gain must of the same performance at a much lower cost.
- de
Thanks, that is what I meant. I followed your supplied links and have just completed ordering the hardware kit and the SSHD that you recommended.
Again, many thanks.
- de
No, Apple systems don't need BIOS tweaking unlike many PC's. You should make sure your systems firmware is upto date before you start. Here's the Apple T/N that explains things: EFI and SMC firmware updates for Intel-based Macs.
- de
Why do you think you need a 1 TB SSD? Depending on your OS level you will have some issues as TRIM services are not available currently via TRIM Enabler due to how Apple now requires signed drivers (Yosemite). Which is why we went with SSHD's for all of our mini's at work.
- de
Mostrar 3 comentarios más
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 207
