mezcla la gasolina con aceite de motor mix gasoline engine oil
Que pasa cuando mezcla gasolina con aceite
What happens when you mix gasoline with oil
Es esta una buena pregunta?
Carlos Santana, it will smoke a lot if you poured oil in the gas tank. It will foul up your sparkplugs and run bad. If you poured int in the oil tank you will lose lubrication and seize your engine. Best suggestion would be to do a complete oil change as well as drain the gas tank and replace with fresh gasoline.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 155
