Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
Preguntas 560 Ver todo
Logic Board of i5 & i7 - difference for replace?
Hallo,
My macbook pro i7 fell to the ground.
Lower case, Upper case and cover of the display is Demage But everything worked perfectly.
I would buy another macbook pro 15" and replace all the internal components of the fallen.
If I buy an i5 model or a 2009 model, can I replace the logic board and display high resolution?
If this is not possible, you can tell the parts relating to the whole of the MacBook casing (including top) ?
Thanks so much.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The i5 components are compatible and interchangeable with the i7 machine. However, due to a complete internal design change, the 2009 model is not compatible or interchangeable with the i5 or i7 models.
Good luck!
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
Roby estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 3,288
