Saltar al contenido principal
El iPhone 5c de Apple fue anunciado el 10 de septiembre de 2013. La reparación de este dispositivo es similar a los modelos anteriores, y requiere destornilladores y herramientas de entrometimiento. Disponible como GSM o CDMA / 8, 16, 32 GB / Blanco, Rosa, Amarillo, Azul y Verde
Preguntas 1232 Ver todo
Dropped phone now blank and screens popping out
So a few days ago I dropped my phone and the screen popped out of the iphone mainframe, I popped it back in but now the screen wont work and I can press down the phone like its still not in properly. Siri still works and I can hear things but when I tried to hard boot it, it stopped responding completely. What do I do?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 7
2 comentarios:
did you solve this bc i have the same issue and i was wondering what did you do?
- de
Replacing the screen is what you do if you already tried reseating the front panel connectors. The LCD cable is fragile on the 5c and can easily rip on drop.
- de
Agregar un comentario
4 Respuestas
One solution to your problem is to make sure that the connection between the display module and the logic board of the phone is intact. Dropping the phone may have dislodged the connection, with continued use causing the internal cable to disconnect. Follow the iFixit iPhone 5c Display Assembly Repair Guide for help finding the connectors for the Front Panel.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
I have the same problem but when I popped my screen back in it had a black splodge in the screen display I don't know what it is
- de
Means the screen LCD display is damaged. Since the LCD and digitizer are fused together you will need a iPhone 5c Front Panel Replacement.
- de
Use this guide but stop at level 8 and do it backwards
iPhone 5c LCD and Digitizer Replacement
Puntuación 0
well same thing had happened here but what i did was hold the home button while holding the power off button and it worked and i was like freaking out before but it worked so i hope this help ^.^
Puntuación 0
well what i did to fix it was hold the home an d power off button at the same time and well ah it was fixed hope it helps bye. ^>^
Puntuación 0
Añadir tu respuesta
Toy Freddy Fazbear estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 13,507
