How can I get my laptop to turn on?
When I press the power button, the laptop will not report any signs of turning on. The charger is plugged into the laptop. What can I do to get it to turn on?
Es esta una buena pregunta?
Your laptop’s battery may be faulty and unable to retain a charge. You’ll need to replace the battery if this is the case. The problem may also result from having a faulty battery adapter. If this is the case you will need to buy a new charger. You can also check out this troubleshooting guide to learn more.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 734
