27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
Preguntas 92 Ver todo
Is there any chance to repair LED backlight (or replace)
Hello, i have Thunderbolt display with fault backlight - there is a picture if you point with flashlight on display and TB display is also in Display settings on my mac. If you are lucky, display turn on after power off and working for a while. Is there any chance of repairing backlight? Thank you. Milhaus
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 4
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
1 Respuesta
Solución Elegida
Sounds like you have a cold solder joint on the logic board on the WLED driver.
Fue útil esta respuesta?
Calificación 4
Comentarios:
Do you think you can post pictures of this? Im having the same issue but the display won't illuminate at all.
por
Jump to Step 12 in the IFIXIT guide: Apple Thunderbolt Display Teardown. It will show you the Supertex HV9982 3-channel switch-mode LED driver IC location.
por
Is there a good DIY way to take care of it? I'm trying to avoid unnecessary costs being a college student.
por
This is preaty advanced for a first timer.
Getting the needed tools will set you back a piece and you still need to locate the part. I would recommend you let someone with the skills & tools do this. I'd hate to see you make a mess of the display here which would be more expensive to replace.
por
Thanks Dan. The monitor did end up working for all of yesterday and I tried it today and the image stopped being illuminated. Do you have any ideas what it could be?
por
Mostrar 5 comentarios más
Añadir tu respuesta
mfrybert estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 25
Todo El Tiempo: 1,094
