CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
Preguntas 421 Ver todo
Why won't my phone charge?
My phone stopped charging. But, I could still play music through the dock connector using my iHome clock radio. So, I assumed the battery was the issue. I replaced the battery and the phone still would not charge. So, I opened the phone and looked at the dock connector piece. I noticed that the water indicator is not completely white. Nor is it completely red (indicating water damage). But, it is about half red. Could the dock connector be the problem? Will swapping it out allow me to charge the phone?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Have you tried charging the iPhone via USB cable?
por
Yes. Since replacing the battery I tried charging via multiple USB cables. The phone doesn't charge.
por
Agregar un comentario
2 Respuestas
Solución Elegida
That's interesting. Since you replaced the battery and the problem still persists I would think that replacing the Dock Connector would be your next best step to take. The only other problem I could think of would be that the cable you were using was faulty, but it sounds like you've tried that already.
There is a repair manual for that procedure with a list of tools and parts you'll need, as well as the instructions to do the replacement.
iPhone 4 Verizon Dock Connector Replacement
Hopefully that'll solve your problem!
Fue útil esta respuesta?
Calificación 2
Comentarios:
Is it possible for sound to play through the dock but not be able to charge the phone?
por
I'm not a Computer/Electrical Engineer, so you might want to take this with a grain of salt, but from what I've read, the 30-pin connector handles different functions with different pins. So basically some pins handle power, some handle audio transfer, some handle video transfer, etc. My best guess is that either one of the pins is not functioning, or the route that power takes through the dock connector may be having problems.
Here's an image I found of the 30-pin connector functionality breakdown if you're interested. http://images.bwbx.io/cms/2012-07-26/tec...
por
You need to turn it in to a repair shop for that model phone.
https://www.apple.com/support/iphone/rep...
Calificación -1
Añadir tu respuesta
DPCLAW1 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 2
Todo El Tiempo: 123
