Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Version 2 of Parrot's toy quadcopter with HD camera, controlled over Wifi by smartphone.
Preguntas 28 Ver todo
Camera connection issues on ar drone 2.0
How do I fix camera issues emergency
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
Kits para Nintendo Switch
Una solución rápida para volver al juego
Comprar kits de Switch
1 Respuesta
Solución Elegida
Did the drone fall from a high altitude? Check the main board for damage as well as the camera "neck". Make sure that all of the wires are connected fully. If you are not receiving any video at all it is most likely that the camera has been damaged and needs to be replaced, which in this case means replacing the entire bottom structure, which you can purchase here. You should also make sure that you have all of the necessary tools. You will need needle nose pliars and varying sizes of screwdriver bits.
Fue útil esta respuesta?
Puntuación 3
Comentarios:
What if the Camera just says Camera emergency but there is still video?
- Por
You are a light in my hobby tunnel!
- Por
how to fix video connection alert in ar drone 2.0?
- Por
even after replacing bottom camera getting same error.
- Por
Añadir tu respuesta
mattandnath estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 25
Todo El Tiempo: 2,783
