Saltar al contenido principal
La más grande de las computadoras portátiles MacBook Air de Apple con micrófonos duales y conectividad Wi-Fi 802.11ac.
Preguntas 465 Ver todo
DC IN Voltage Fails TechToolPro Diagnostic
I have a MacBook Air that sometimes doesn't startup at all.
So I ran the TechTool Pro 8 diagnostic on it and it has a sensor failure: DC In failed at 16.96v.
Does anyone know if there is a way I can fix this other than a new motherboard?
Es esta una buena pregunta?
Puntuación 2
1 comentario
You may be using the wrong power supply. The Air uses a 45 watt power supply at 14.5 volts. All the other laptop products use a 16.5 volt supply. So if you hook up a MacBook Pro power supply you're going to see 16.5V to 17V on the DC-in rail (depending on the accuracy of the sensor).
- de
Agregar un comentario
3 Respuestas
Solución Elegida
The Mag-Safe is built into the I/O board. There does not seem to be a repair guide for this machine but there is one for the A1466 2012. Take a look: Reemplazo de la placa de E/S del MacBook Air de 13" mediados de 2012
Fue útil esta respuesta?
Puntuación 2
I just replaced the part for a brand new one from IFIXIT and it didn't fix the problem.
I'm still get the DC-in Rail 0 Failed at 16.67 V.
Anybody else managed to fix it?
thx
Puntuación 0
1 comentario:
You'll need to trace the voltage from the I/O board back to the main board as you have a disconnect along the pathway.
- de
I had the same issue and I fixed it by using the right charger. No more errors now!
Puntuación 0
5 comentarios:
Right…charger??
- de
Are you saying that you can use a Thunderbolt 1 port to charge a MacBook Air??
- de
Use a genuine Apple 45W charger. Fake chargers do not have a stable voltage and can cause this issue.
- de
Oh, the *correct* charger! I thought he was charging through the right side—i.e. the Thunderbolt port.
- de
He was using the wrong power supply. The Air uses a 45 watt power supply at 14.5 volts. All the other laptop products use a 16.5 volt supply. So if you hook up a MacBook Pro power supply you're going to see 16.5V to 17V on the DC-in rail (depending on the accuracy of the sensor).
- de
Añadir tu respuesta
randy4 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 3,262
