Saltar al contenido principal
Repair information for the Asus Transformer Book T100TA. Released ~2013. Model number: T100TA .
Preguntas 76 Ver todo
Pregunta Cerrada
Damaged docking port on Motherboard
Hi
I damaged the docking port on the Tablet, not the keyboard, while separating them. Is it possible to repair / replace port without renewing the motherboard.
Thanks
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
ross orr, that connector is soldered to the logic board. It will require microsoldering equipment and skills. The other issue will be to find a proper replacement connector. Not an easy task, so you may have to consider changing the complete board. you may consider posting an image of your damaged port with your question so that we can see what you see. For that use this guide.
Fue útil esta respuesta?
Puntuación 1
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 457
