Why won't my camera turn on?
When I press the power button, nothing happens.
Es esta una buena pregunta?
The simplest reason for this problem is an issue with the battery and charging system. Make sure you are using the proper USB charger and cord and they are not malfunctioning or damaged. If everything is working normally there may be an issue with your battery, which you can replace by opening the battery compartment.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 482
Mine fell down and the lens never eject
- de S`busiso mqapheli
