Saltar al contenido principal
Guías de reparación y soporte para teléfonos fabricados por Oppo Electronics Corp.
Preguntas 200 Ver todo
Is my charging port going bad?
Hi! About a couple months ago my Oppo Find 5 (OPPO X909) started having issues with charging and eventually reached the point where it won't charge anymore. I thought it was the battery at first (which I may replace anyways assuming I find a way to fix this issue) but then I found that the charging port itself was the issue. I would have to bend the charger in a certain way just to get a connection or it would just stay plugged in but not charging. I tried going to a couple different cell phone repair services but none would work on an oppo phone. Would it be best at this point to get a newer phone (after taking out the internal SD) or do I have a chance of repairing it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
I have the same problem too....
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
purplegill10 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 2,730
