Saltar al contenido principal
Xbox One Kinect. Incluido con la Xbox One. Ha vendido con éxito más de 23 millones de unidades en todo el mundo.
How to best re-atach the cable?
I did remove the cable on my Kinect by pulling it out using some force.
Now I want to plug it in again. Has anyone any tips on how to do that properly?
Pictures on the rotation of the cable, the process and a few tricks would be very much apreciated.
I could also use a picture of how the port is supposed to look when it is not damaged to compare it to.
This might be helpful to people in the exact situation as I am- be it because of curiousity or because the cable needs to be swapped out.
Update: Just to clarify: Nothing is definitely broken- just need help figuring out how to plug the cable in again without killing the port.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios:
goldsteal, it will help if you attach images of your damage and your cable. Use this guide Agregar imágenes a una pregunta existente for that
- de
Simply plugging in the cable is not possible due to the rubber preventing it. Do I need to open the Kinect? Is there a trick?
- de
Agregar un comentario
2 Respuestas
Hello,
i had this issue and i solved it at the cost of the rubber inside the kinect port at the back of the kinect
i used a flat screw driver to push the rubber which you can see it surrounding the port to the outer side. then, i took it out. after that, i plugged the cable and it was easier without rubber and i managed to successfully connect it by doing this only.
don't worry, you can put the rubber back if you wanted in the future.
i hope this would help
Thanks and Regards
Fue útil esta respuesta?
Puntuación 0
Alternatively, you could cut off the wings on the plug, all 4 wings. The cable can be plugged in directly just like a usb 3.0 type b cable, once you have done so. It won't be as snug or as secure as before, but it's not likely that anyone is ever going to pull on it anyway .
Puntuación 0
Añadir tu respuesta
goldsteal estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,454
