Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 4086 Ver todo
Apple logo then off after battery swap.
Hi all,
An iPhone 5s (Verizon, CDMA) has gone into a type of boot loop that I'm not too familiar with. About a month ago a customer came in to get a battery replacement and not the phone will not move past the apple symbol during the boot sequence. Everything was fine with the repair up until a night ago.
I've tried to change the battery, tried a different screen and tried a different charging port. Still all with the same issue.
I am noticing that when the phone is plugged in, I can see light coming out from between the metal back of the screen and LCD.
I'm totally at a loss here and hope you can help!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
possible pry damage? check components near where you pryed the battery up
Fue útil esta respuesta?
Puntuación 0
Comentarios:
Ill check today and get back to you.
- de
Check for pry damage. Alterinatively check the solder to the Battery FPC Connection to ensure that it hasn't come loose. I've had this problem a few times in IP4/4s and had to resolder it.
Puntuación 0
Comentarios:
- de
Añadir tu respuesta
Aaron estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 119
