Saltar al contenido principal
Una cámara de 10 megapíxeles para apuntar y disparar desarrollada por Canon en 2010.
Preguntas 20 Ver todo
Why isn't my flash working?
Even in the darkness, my flash isn't functioning to make bright photos. I have the settings how they should be, but nothing is helping. What could be the problem?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
  • The flash is not turned on. Turn the flash setting on. There is typically a manual setting.
  • The bulb is burned out. A replacement is needed.
  • The wires between the battery source and flash may be disconnected. They must be reconnected.
Fue útil esta respuesta?
Puntuación 0
There could be a couple of different reasons. Most likely, it's an issue with the settings on your camera. On the top dial, turn it to an automatic setting so the camera will do the focusing for you. If that doesn't work, it could be an internal issue that will require replacement or repair.
Puntuación 0
Añadir tu respuesta
Nathan Meuwissen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 483
