Saltar al contenido principal
El PowerMac G5 es un ordenador de escritorio producida por primera vez en 2003 por Apple Corporation. Esta guía revisará el proceso de reparación de un número de modelo Apple PowerMac G5 A1047 EMC 2061 de 2004.
Preguntas 193 Ver todo
Why are my fans so noisy
The fans run very loud all of the time.
Es esta una buena pregunta?
Puntuación 1
1 comentario
Have you done any interior work?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
When u say "all of the time" im gonna assume that they're running on high even when you're Idle. First things first, I would make sure that there are no background processes using up your CPU's resources. if thats not the case and your machine is in a properly ventilated area, then I would have a look and clean up the fans with compressed air. If this doesn't remedy the situation, then I would replace the fans. Power Mac G5 Bottom Right Cooling Fan Unit Replacement
Power Mac G5 Top Left Cooling Fan Unit Replacement
Imagen de Power Mac G5 Bottom Right Cooling Fan Unit
Guía
Dificultad:
Fácil
5 - 10 minutes
Imagen de Power Mac G5 Top Left Cooling Fan Unit
Guía
Dificultad:
Fácil
5 - 10 minutes
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
I also recommend you install a Fan and Temp monitoring utility like SMC Fan Control.
- de
Maj. - wait for more info before recommendations, please.
- de
I have iStat Widget that monitors temp and fan RPM. Most of the areas are over 100 Degrees. Monday I can get an exact reading of the interior and let you know. I guess it could be overheating and not bad fans. Fan replacement looks fairly straight forward, but heat sinks I would think are a different story.
Thanks,
Gerry
Puntuación 0
Añadir tu respuesta
Gerry Beane estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 3,436
