Saltar al contenido principal
El reloj inteligente orientado a la aptitud física, con una pantalla táctil curvada super AMOLED. Primero lanzado en abril de 2014.
Preguntas 20 Ver todo
gear fit won't turn on,
ive held down the button, ive charged it, i disconnected bluetooth,i did not drop it, and still nothing but a black screen. ive had this for 3mos so i know the battery should be fine and all the connections are clean.
any other suggestions?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
it does vibrate when i hold the button down, but thats it.
- de
Agregar un comentario
1 Respuesta
I've had something like this happen in the past. It should just need a reset, if you haven't tried that already. Plug it into the charging cradle and hold the home button for 7-10 seconds to reset it. Turn the bluetooth connection off from your phone while the Fit is off. When the Fit restarts, you should be able to turn bluetooth back on and reconnect it.
If you have tried a full reset, then I'm sorry.. no other ideas. I wish you luck.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
karen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,342
