Upgrade to IPS 768 screen, which panel?
I'd like to upgrade my x202e Vivobook to a 1366x768 IPS screen. I know Asus has them in some models, so I'm wondering which panel I should get that will work with my machine.
Es esta una buena pregunta?
erniekeller, since it is not a direct replacement, this could be a hit or miss. You have to make sure that the replacement panel uses the same connections as well as the same signals. For that you need a datasheet of the current display as well as a datasheet for the replacement you choose and compare those.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 551
