Saltar al contenido principal
¡Todo lo que necesitas para reparar tu iPhone tú mismo! IFixit tiene guías de reparación e información de desmontaje gratuitas para cada iPhone, como también los mejores recambios y herramientas en la galaxia.
Preguntas 37219 Ver todo
Glass replacement issue that nobody seems to know the answer to
So I don't know did anyone can answer this question but recently I have done an iPhone 6 and iPhone 5 glass replacement. After I cured the uv glue under a uv light I cleaned excess glue off and turned the phone on only to see that the screens were very discolored. I think this is because of the glue but I'm not sure if anyone knows why this happens please respond!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
looks like it got under the lcd :(
Fue útil esta respuesta?
Puntuación 1
Hi , this is the issue with cutting Iphone screens and using UV glue to attach a new one. the glue gets between the LCD and backlight. this is what causes what you are seeing. you will require a new backlight. An alternative to loca is OCA - Optically Clear Adhesive (Sticker but needs autoclave to remove bubbles).
Puntuación 1
Comentarios:
Is there a way to prevent the glue from getting under the backlight and how does the OCA work or the autoclave
- de
Añadir tu respuesta
Joe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 85
