The 2014 edition of the Kindle, part of the 7th generation, includes a touchscreen and same form-factor as the Kindle Paperwhite, but lacks the backlight.
Preguntas 17 Ver todo
Why won't my Kindle 7 turn on?
My Kindle 7th Generation won't turn on despite pressing the power button. Why is this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Hard Reset your device by holding the On/Off button 40 seconds or until you see a picture of a tree with a boy reading underneath it. If the Kindle doesn't boot set it to charge for about 2 hours or even better over night and try hard resetting the device again. If this doesn't work you can assume that it's a hardware issue and proceed to contacting client service.
Fue útil esta respuesta?
Calificación 5
Comentarios:
Worked first time, very good and thanks.
por
Worked perfectly following your suggestion. Thanks
por
Well, Mitchell, there are a lot of reasons why this could be. The most common answer is the Kindle simply isn't charged. Find a micro USB cord and plug your kindle in.
Other reasons why your kindle won't turn on are more serious problems such as battery or motherboard failure. Don't fret because you can figure out how to replace the battery and replace the motherboard here!
Be sure to head over to trouble shooting to narrow the problem down!
Imagen Kindle 7th Generation Battery
Guía
Kindle 7th Generation Battery Replacement
Dificultad:
Moderar
15 - 20 minutes
Imagen Kindle 7th Generation Motherboard
Guía
Kindle 7th Generation Motherboard Replacement
Dificultad:
Moderar
20 - 25 minutes
Calificación 1
Press the Start button for 40 to 50 second repeat the same procedure two or three times. After this trick if problem resist you can another do another try by replacing the Battery. Or you can call us any time (877-330-0887) or just follow the link http://kindlehelp.org
Calificación 0
Añadir tu respuesta
Mitchell estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 27
Últimos 7 Días: 118
Últimos 30 Días: 616
Todo El Tiempo: 6,489
