Dial 1-888-966-6097 to Resolve How to Connect Brother Printer to Wifi Issue. In this era, most of the business owners rely on Brother printers to fulfill their printing requirements. It is all because of the exceptional and reliable printing solutions that this printing device offers. To be honest, this piece of equipment has spread its wings in the printing industry. If you have the desire to obtain high-quality printed documents, it’ll be worth it to connect Brother printer to Wi-Fi.
Are you curious to be aware of the complete process of establishing a strong connection between your printer & Wi-Fi network? If so, you need not take much stress for it. Here in this blog post, we have shared useful information regarding connecting your Brother printer to Wi-Fi. All you need to do is explore the whole setup process and kickstart it.
Without much delay, let’s get started!
Step-by-step process to connect Brother printer to Wi-Fi
The process of connecting your Brother printer to a Wi-Fi network enables you to print wirelessly. It is possible for you to do using a range of devices. These devices are - computers, smartphones, and tablets. Here in this section, we have given you a detailed and comprehensive process to assist you in connecting your Brother printer to a Wi-Fi network. So, why are you thinking too much about it?
Just calm down!
Let’s move ahead and dig a little deeper into this section!
1. Prepare Your Network Details
In the first step, you need to ensure that you are familiar with the name of your Wi-Fi network. Next, it is also required for you to double-check that the Wi-Fi password is ready.
2. Power On the Printer
Next, you have to turn on your Brother printer. For this, you have to press the power button. Later on, it requires you to wait until the printer is completely powered up and ready.
3. Access the Printer’s Control Panel
In this step, you have to locate the control panel on your Brother printer. Usually, it includes a menu button and navigation keys.
28 comentarios
What's the model number of the printer?
- de mayer
thanks everyone ..it was very helpful
- de vaidya
If you've recently switched from 2.4GHz to 5GHz wifi - this is the problem! Brother printers cannot connect to 5GHz wifi, but if you ask your internet provider, they can split the combined network into two separate networks, a 2.4GHz one and a 5GHz one - then connect your printer to the 2.4GHz!! I spent far too long trying to figure this out, so I hope this saves someone the hassle.
- de e.crawley73
Turn on your Brother Printer
To reset the wireless connection press the Menu button
Press OK.
Select Network Reset.
Press 1 to Select Yes.
Press 1 again to confirm the reboot
The printer will now reboot and the network reset has been successfully done.
Follow the next step in order to connect your Brother Printer to Wi-Fi.
Connect Brother Printer to Wi-Fi
Once you restart the Brother printer after the network reset you’ll see a message Wi-Fi setup will start. Refer to Quick Setup Guide
Then Press OK
Press Ok three times to get inside Setup Wizard
A message will appear on your screen Enable Wlan? Press Ok to accept. Press Ok Again
Wait for a moment while it searches a wireless network
A list of SSID will appear on the screen choose the Wi-Fi network you want to connect with and you need WEP Key/Wi-Fi Password of your router to connect Brother Printer to Wi-Fi
Enter the Wi-Fi password using the Brother Printer Keypad
Next Press Ok and then Press 1 to apply the settings
- de pcasta premium
Get as far as entering wireless network but doesn’t ask for password?? And so just reverts to home screen??
- de David Bartlett
Mostrar 23 comentarios más
