Briggs & Stratton 190cc Model 120000 Quantum 675 Series Lawn Mower Engine. Released February 2011. For Toro 6.75 ft-lb torque Lawn Mower.
Preguntas 28 Ver todo
The engine cover is cracked, will this affect the performance?
I dropped my hammer on my engine and now the cover is cracked exposing the engine parts. Is this bad for the engine?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Comentarios:
Do you mean the top plastic cover, or the metal cover over the engine?
por
I meant the plastic cover.
por
Agregar un comentario
1 Respuesta
Solución Elegida
The plastic cover on the top of the engine is mostly for appearances, so if it is cracked it should not be a problem. However, the middle section of the cover is designed to act as a small filter so that big items do not get in the engine, so if this portion of the cover is completely broken, you may want to think about replacing it.
Fue útil esta respuesta?
Calificación 1
Comentarios:
Only the corner is cracked so I'm guessing I'm fine. Thank you Mr. Wirtz.
por
Añadir tu respuesta
Taichi Nakahara estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 18
Últimos 30 Días: 62
Todo El Tiempo: 2,145
