Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 2375 Ver todo
iPhone not charging but turns on when I plug in the charger
iphone not charging but it turns on when i plug in the charger. I cleaning dock connector, try new cable, checking battery connector, replace battery, still not charging, please help.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Ondrej, make sure that the battery connector is properly seated and connected. Of course it is possible that you have a failed charging coil or "USB fuses". You will at least need a multimeter to check those components for continuity.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
thanks! coil and fuses are OK, I dont know how i can test that ic. but i think this isnt that problem. can i somehow test dock connector ? charging is working before, then i opened the phone, repairing something and then, when i connect the charger, is indicating charging, but nothing happend, still the same battery percentage, i find battery connector was desoldered from the board, i solder it back and then not charging... but the phone on the battery working, and when its off and i plug in the charger its powering on, but no charging...
- de
Añadir tu respuesta
Ondrej estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,440
