Saltar al contenido principal
Modelo A1278 / 2.26 o 2.53 GHz Procesador Core 2 Duo EMC 2326 de mediados de 2009
Preguntas 745 Ver todo
Upgrading Logic Board with Core Duo to i5?
Hello everyone!
I have a 2009 MacBook pro, 13'' with a 2.53Ghz core 2 duo. What i would like to know is if it's possible for me to upgrade my logic board to a more recent one, like for instance, a mid 2012 Intel Core i5.
If so, it would be much apreciated if you would give me some advice on how to replace it and alert me to anything that i should take mind of, like mounting issues, ports, and maybe some solutions do those issues!
On advance, i give you my humble thanks :)
Es esta una buena pregunta?
Puntuación 1
1 comentario
So I want to swap my 2010 MacBook Pro 13 core 2 duo's logic board with a 2010 MacBook Pro 13 i5's logic board, is that possible? from the port alignment it seems like it would work but I just wanna be absolutely sure. Also if I could use a newer i5 board, how new could I get it?
- de
Agregar un comentario
4 Respuestas
Solución Elegida
Sadly, its really not possible.
Apple changes things around to such a point you really can't fit a different series logic board into your system,. Here's the EveryMac spec sheet for you system and the first possible i5 system:
As you can see the ports alone are different and are not aligned the same within the case. You can also review these IFIXIT guides:
As you can see there are enough differences in the heat sink and the mount points that you'll need to over come.
Basically, it will be cheaper to buy a used newer model than retrofit a newer logic board into your system.
Imagen de MacBook Pro 13" Unibody Mid 2009 Placa Lógica
Guía
Sustitución de la placa lógica del MacBook Pro 13" Unibody Mid 2009
Dificultad:
Difícil
40 minutes - 2 hours
Imagen de MacBook Pro 13" Unibody Early 2011 Placa Lógica
Guía
Reemplazo de la placa lógica de Macbook Pro 13" Unibody Principios de 2011
Dificultad:
Difícil
20 - 35 minutes
Fue útil esta respuesta?
Puntuación 4
I want to change my logic board from a macbook pro 2009 core 2 duo to a i5 logic board from a macbook pro 2010, is it possible? I only saw some differences between the battery, but I don't really know if there are more changes in the logic boards
Puntuación 0
2 comentarios:
Not really possible, please read above for the full details.Time for a newer system (new or used)
- de
Hi! I just did this with a mid-2009 logic board --> early-2011 logic board. While the lboard seems to fit properly the camera cable is different, WiFi/Bluetooth connect differently, and it seems only one of the USB ports is actually functional. That said it did technically work and via OCLP I'm now running the latest Sonoma on it.
- de
On the 13 inch, you can swap logics freely between 2009 and 2010 (both Core2Duo, but there are internal changes, bus speed, faster processors that make this an upgrade, and you can swap in a faster processor logic), but no others.
You can swap freely between early and late 2011 (again for faster processors and Apple-undocumented design flaw revisions).
The 2012 13”, at the least, has a different SATA cable than the previous years, and a couple of connections on the logic that are transposed but within the tolerances of the cables on the 2011; and I have not experimented with this swap out, self.
On the 15”, you lose that freely swapping ability between 2009 and 2010 because the changes in board design to use the i5 vs the Core2Duo moved other things around on the board.
When in doubt, you can lookup the board replacement instructions here for the different years and compare the pictures and notes.
Puntuación 0
2 comentarios:
Hi Infografix,
Many thanks for the comprehensive answer. If I may ask with which logic boards can I fit 2010 15'' MacBook pro? Can I go up to 2012?
And if you had the chance to try out 13'' MacBook pro early 2011 upgrade to 2012, does it work?
Thanks again and I hope you find the time to answer my queries.
- de
So I can swap my 2010 MacBook Pro 13 core 2 duo's logic board with a 2010 MacBook Pro 13 i5's logic board with no problems? and if I could use a newer i5 board, how new could I get it?
- de
Hello:
Does someone know if there’s any manufacturer who builds personalized motherboards? This would be a really interesting idea in order to recycle many good hardware cases, even if they ended being a usual PC. For example: replace apple broken logic board 2011 for a new EFI motherboard (asus, MSI EFI) to keep working computer with Linux or whatever OS you prefer.
Puntuación 0
Añadir tu respuesta
Andrade estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 26
Todo El Tiempo: 11,680
