Why won't the Netgear WNDR3800 power button turn green?
It was working fine earlier this morning but, when I got home this afternoon the power button won't turn green or any of the parts. The power did go out while I wasn't here but everything else seems to be working fine. It will blink every so often and the power button would stay Orange. Also when I tried switching out the power switch with the Cisco switch it came on but I was not receiving any internet connection.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
you just need to setup the router for more steps http://goo.gl/d1EhUX
por
Agregar un comentario
3 Respuestas
Try resetting it o the factory settings. Usually when the led do not turn green and remains amber it means some issues. Depending on your knowledge you can troubleshoot ore fix it :)
some basic instruction Why are all LEDs flashing?
OS
Fue útil esta respuesta?
Calificación 0
Have you checked out the connection between your router and modem. make sure your modem is properly connected from internet port of the router to the modem.
after making the connection between router and modem. you need to reboot your netgear router. for more information you may visit at: netgaer router flashing orange
Calificación 0
Try to unplug the router from modem and power both. wait for 1 minute and then plug your modem to the router first. now you need to power on your netgear router. it should be working fine.
If it's still not working, try to factory restore your router and reconfigure it. for more information, you need to visit: netgear router blinking orange
Calificación 0
Añadir tu respuesta
Amber estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 5
Últimos 30 Días: 13
Todo El Tiempo: 515
