Saltar al contenido principal
La segunda generación del iPad con modelos Wi-Fi, GSM y CDMA. Algunos modelos se actualizaron antes del iPad 3. La reparación es difícil y requiere calor y palanca.
Preguntas 730 Ver todo
Motherboard issues won't restore
So I have an iPad 2 and an iPad mini which seem to have similar problems. Both are recognized by iTunes as being in recovery mode. The problem is that when iTunes tries to upload the latest firmware to the iPad iTunes just hangs on waiting for iPad. Both iPads boot up to the Apple logo and show an empty status bar underneath the logo and that's it.
I've put both logic boards under a microscope and there are no obvious signs of damage. I was hoping that someone on here may have solved a similar problem or at least had some trouble shooting directions. I've tried multiple PCs and doc cables but no luck.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
1 comentario
So do I...exact same problem...otherwise my iPad 2 looks like the day I bought it...not a scratch anywhere...so I am inclined to think that a hardware failure is the root cause...instead I seem to suspect that when the latest version of IOS came out...might be related...not sure if my iPad 2 was configured to automatically upgrade it's firmware or not or if this was even an option...otherwise, I am stuck with a boat anchor now...thanks
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hello Brian, you can try a different connector port from another ipad that works, but I'm not sure if that will be the problem, it's hard to know!
Good luck dude, keep us posted if you want
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Shouldn't even answered the question, if you cannot solve the problem keep the question against you chest and wait until someone come up with a solution.
- de
So do I Brian...exact same problem...otherwise my iPad 2 looks like the day I bought it...not a scratch on it anywhere...so I am rather inclined to think that a hardware failure is NOT the root cause...instead I seem to suspect that when the latest version of IOS came out...this might be related...also not sure if my iPad 2 was configured to automatically upgrade it's firmware upon a new release and/or whether this was even an option...otherwise, I am stuck with a boat anchor now...the iPad store techs don't have any idea either...thanks
Puntuación 0
Añadir tu respuesta
Brian estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,035
