Guias de reparacion para varias marcas de computadoras laptops de PC.
Preguntas 8957 Ver todo
HORRIBLY slow download speeds in iTunes, Help!
I'm using a Windows laptop, (Windows 7). Had it for a couple years, runs fine.
Internet speed is normal, but im trying to restore various iPhones but the software for the updates and iTunes its self won't download.
It says around 120 hours remaining and then errors out. Help?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Comentarios:
and i have already restarted the computer, and uninstalled and reinstalled itunes.
por
How are you connecting your system directly via Ethernet or WiFi? Do you have a second system which is working though your cable router?
por
Agregar un comentario
1 Respuesta
Solución Elegida
Take a look at your systems resources. Do you have at least 1/3 of the HD free? Have you tried defragmenting your HD? If your system is highly fragmented it can cause slow file transfers. You can also have a drive thats starting to fail as well.
Try connecting via direct Ethernet to your router, Is that any better?
What are your iPhones? You maybe able to download directly over the cellular network (check your service contract first! Some limit you on how much as well as how fast).
Don't forget your internet connection is not symmetrical (same data rate up & down) must are asymmetrical (very slow up and faster down). Why this is important is if you are saving to your iCloud account. Make sure you don't enable iTunes Match services until you've upgraded your iPhones.
Check your internet connection using this free app: Network Speed Test.
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
Austin Harris estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 12
Últimos 7 Días: 94
Últimos 30 Días: 414
Todo El Tiempo: 22,972
