Saltar al contenido principal
Guías de reparación e información de desmontaje para portátiles PC de todas las formas, tamaños y colores.
Preguntas 18917 Ver todo
HORRIBLY slow download speeds in iTunes, Help!
I'm using a Windows laptop, (Windows 7). Had it for a couple years, runs fine.
Internet speed is normal, but im trying to restore various iPhones but the software for the updates and iTunes its self won't download.
It says around 120 hours remaining and then errors out. Help?
Es esta una buena pregunta?
Puntuación 3
2 comentarios
and i have already restarted the computer, and uninstalled and reinstalled itunes.
- de
How are you connecting your system directly via Ethernet or WiFi? Do you have a second system which is working though your cable router?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Take a look at your systems resources. Do you have at least 1/3 of the HD free? Have you tried defragmenting your HD? If your system is highly fragmented it can cause slow file transfers. You can also have a drive thats starting to fail as well.
Try connecting via direct Ethernet to your router, Is that any better?
What are your iPhones? You maybe able to download directly over the cellular network (check your service contract first! Some limit you on how much as well as how fast).
Don't forget your internet connection is not symmetrical (same data rate up & down) must are asymmetrical (very slow up and faster down). Why this is important is if you are saving to your iCloud account. Make sure you don't enable iTunes Match services until you've upgraded your iPhones.
Check your internet connection using this free app: Network Speed Test.
Fue útil esta respuesta?
Puntuación 2
Tôi dùng máy tính Windows 10 Home Premium, Mạng Spectrum với đường truyền ethernet 180 Mbps để download ipad mini 2 software restore device bị lổi đăng nhập. Máy làm việc chậm và dự báo cần 15 giờ để hoàn tất. Ôi ông già Táo ,gối mỏi chân chùn thì nên tránh đường cho các hảng khác phát triển với !
Puntuación 0
1 comentario:
Âm thanh như kết nối internet của bạn không được tốt lắm! Thường thì tốc độ tải lên rất chậm và tốc độ tải xuống nhanh hơn nhiều vì họ cho rằng bạn đang nghe hoặc xem nội dung trực tuyến không tải lên iCloud.
Sounds like your internet connection is not very good! Often the upload speed is very slow and the download speed is much faster as they assume you are listening or watching online content not uploading to iCloud.
- de
Añadir tu respuesta
Austin Harris estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 29,106
