Why is my flash not working?
The flash on my camera is not working and I can not figure out why.
Es esta una buena pregunta?
You should try following this simple procedure to get your camera's flash up and working again. You will want remove the battery and memory card and reinsert both after a couple of seconds. You will then want to turn on your camera and place it on Auto Mode. Try seeing if the flash works now by pressing the shutter button on to take a picture.
Hope this helps!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,866
i am having same problem, could you find a solution?
- de 123456
