Saltar al contenido principal
Lanzado en Septiembre 19, 2014, este iPhone con pantalla de 4.7" es la versión pequeña del iPhone 6 Plus.
Preguntas 4718 Ver todo
Can't hear my phone calls. How to fix it?
Hello guys.
I live in Ukraine. My friend from California bought iphone 6 and brought it to me, so have no possibility to return it back to Apple, we haven't got autorized apple distributors.
After unboxing I recovered it with my iphone 5s backup . And tried to make a call, all I heard was Nothing. Another person always hear me well but I don't hear anything even if I switch to the speaker and headphones as well.
I tried to use skype. it works I do hear everything. So made a conclusion that my earpiece works as well as speakerphone, because it works in youtube app and etc.
What I've already tried:
- Restore it from iTunes (3 times)
- Tried another sim card of another carrier.
- My sim card works in iphone 5s, checked all the problems might be related to carrier.
- Chatted with Apple support (2 consultants, 1 supervisor, all options exhausted)
I found smth related to my question here I can't hear my phone calls unless I put it on speaker., but in my situation speakerphone doesn't work also while calling and I'm sure my earpiece is not broken, it's some kinda software bug, that makes my phone a brick
Maybe smb have faced with such issue and can suggest something valuable,
thank you
p.s. sorry for my English
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 19
Comentarios:
i had try to chaner my prepay phoe number to a smart phone but just to get a new number ijust want it on my flip phone my no was 4068684376
por
what is my best frind
por
I can’t hear my caller Nd my caller can’t hear me unless I put it on speaker wat can I do
por
Agregar un comentario
Kits de Reparación de Batería de iPhone
Sólo $29.99
Buy Now
Sólo $29.99
Buy Now
23 Respuestas
Solución Elegida
iPhone 6 can't hear caller issue is more common then you think. There are a lot of different causes for it.
I assume you took the plastic cover off? I have seen many cases where the issue of not being able to hear is because the person hasn't taken the film off the new phone.
Try to plug in some headphones and take them out, it might correct the issue.
Put some pressure to where the ear piece is connected, the connection might have gotten loose.
Check to see if blue tooth is connected. Turn it off.
Do a hard restore without the sim card being in the iphone 6.
Make sure ios is updated.
Is this iPhone unlocked? As in can you put any carrier on it? It might be for a specific carrier like AT&T or Verizon.
This iPhone 6 might not be compatible with your carrier as it is from America.
Fue útil esta respuesta?
Calificación 10
Comentarios:
the pressure to the ear piece worked like a charm
por
Great! :) @tcatchings
por
Okay well I dropped my phone in the toilet and got it out fast once I saw it I cleaned in I blow on it and it worked but 5 hours later the sound doesn't at work Its not on silent or anything but it still doesn't work help me please do I need a new phone? And yes it's an iPhone 6
por
I am laughing at myself right now. I thought the original film was screen protector. No wonder my new iphone had this problem. I am a lady, I admit.
por
The pressure on the ear piece worked like a charm, thanks !!
por
Mostrar 8 comentarios más
Go to voicemail. Put on speakerphone. Rapidly tap mute and speakerphone about 10 times. This worked for me when nothing else would.
Calificación 8
Comentarios:
It works , you can call any number by the way. I called my house phone
por
Thank you for this post Dwayne, that worked for me as well! A bit unnerving that the solution is about as high tech as waving a dead chicken over my head. ;)
por
Thank you! I was skeptical, but it worked. I echo Rick's comment regarding the "high-tech "solution.
por
Hi Dwayne,Im from Malaysia,i dont know who you are,but seriously thanks alot man,It worked for me....!!!
por
Worked for me. Thank you for sharing.
por
Mostrar 2 comentarios más
There is a repair issue, that covers this. However this appears to be some kind of software thing, and possibly related to carriers. Like just previously stated. You're using an overseas carrier, where this phone was intended for an American carrier
Calificación 3
Comentarios:
I forgot just how far your answers have come recently. What repair issue? Can you get a bit more nebulous?
por
I don't...I don't get it @mayer. What I was probably saying is front camera flex. What I was getting at here, I think I was wrong. Cause aren't iPhone carrier locked in the states, but weren't they meant to be used internationally? It's so confusing with apples constant changing rules
por
@imedic congratulations, you got more nebulous. I'm sure glad you give better answers today ;-)
por
I agree @mayer. My answers were so bad. Now I'm pulling a you, and I'm all "don't you think you should post a link with that answer?"
por
I tried everything listed above. Nothing worked. So out of desperation I literally ran the tip of my tongue across the ear speaker several times. Then I dried it on my shirt and blew in it a couple times. Worked!!
Calificación 2
Comentarios:
Omg my earpiece speaker has not worked in 3 months and I tried this and it work!!!!Thank you sooo much
por
Hey im from Malaysia..what i can said is god bless u dear! I did this on my way to repair shop and it work!!? My last choice and i hd done everything else..literally taking this method as a joke buy yeayyy it work!!?!!
por
Thank you! My husband read your post, licked my phone and now it works.
por
Solved mine by sucking on the earpiece. Crazy but it was recommended on line for iPhone 4, so I tried it on my iPhone 6, and it worked. I felt rediculous, but it worked like a charm.
Calificación 2
Comentarios:
I thought you were kidding. After trying a bunch of these, they didn't work. I then decided to try your fix. After sucking on my earpiece (that sounds so awful) IT WAS FIXED! Thank you SO MUCH!!! I really can't believe this worked. LOL.
por
This def works. Tried it myself not too long ago!
por
Try going to settings/Cellular. Then from there Enable LTE to Voice & Data. Not to sure if that will help but it cleared up the same problem I had with my 6. I live in the U.S though..
Calificación 1
Comentarios:
didn't help :(
por
This worked on my phone after restarting it. Thanks
por
Long shot - is the protective front plastic still on the device? If so, it would hinder the volume on the headset speaker.
Calificación 1
Comentarios:
Right on! After a 1 1/2 days of trying to get my new Iphone 6s to work-at Sprint and Apple and Sprint eventually giving me a new Iphone 6s, I dreaded having to go back to the store. I thought I had another lemon. Your fix worked like a charm.
por
Don't waste your time on all of the other stuff. None of that stuff up there worked. I saw a comment on another forum about sucking on the headphone jack and tried it. I burst out laughing because it was the only thing that actually worked, when I initially thought it was a joke. Lol. Thank you so much!
Calificación 1
I would try going to setting and go to restore to factory default settings . the after it turns off and back on i would shut it down one more time and hopefully it will work mine did
Calificación 0
Your phone will only work in uk
Calificación 0
I have repaired two iPhone 6 units hear with the same problem. The ear speaker has small connectors that touch a ribbon type cable. It is possible one of the screws on the shield backed out and the connection isn't stable.
To open the iPhone 6 is quite easy if you utilize a iSesamo or iSclack from iFixit. You would just need a pentalobe screwdriver as well as a Phillips and a nylon spudger. Follow the iFixit guide on replacing the digital display on the iPhone 6 and when you have removed the battery cable shield and disconnected the battery and have moved the emi shield and have disconnected the display cables you will be able to access the shield covering the ear speaker. It has 3 screws holding it in, they are Phillips type, check first to see if they are snug(tight) if not that could be the issue.
Just follow the iFixit guide from there. If it still isn't working please contact me, I will gladly help via online if I can.
Calificación 0
Easy fix take a toothbrush and clean the ear phone. A toothbrush will brush away the ear wax that has built up blocking the air from moving in and out.
Calificación 0
In settings/Cellular I disabled Cellular and LTE then enabled them again, then I used a compressed-gas duster for electonics such as keyboards on my ear speaker and headphone jack. Problem was resolved. I dont know if it was one thing in particular that did the trick or it was all of the above. However, my ear speaker issue was resolved.
Calificación 0
I am having a similar issue with my phone. I can't hear other people when I try to use the ear speaker, however they can hear me talking. My speaker phone works fine. On top of this, my front camera isn't functioning, as it won't open and causes the app to freeze. I ordered a new front camera flex cable, as this is what I diagnosed the issue to be. I put another screen (that has a different flex cable assembly) onto my logic board and the earpiece and camera worked fine. To be sure, I even put my ear speaker into this different assembly and it worked on my phone. I get the parts later this week, and will post again with the results of my repair.
Calificación 0
I pressed an ear bud in the ear piece not expecting it to fix it But! It did!! It looked clean but I still did it and sounds come back , I think I may have pressed the speaker and got connection again from loose speaker wires perhaps. See if it goes dead again Cheers rowefred for your comment from 10/14/2016 lols 14?
Calificación 0
My phone did the exact same thing! Mine is a Iphone 6+ if your phone doesn't have the newest update update it or if it does just restart it I did that and it worked like it as brand new. Try that or even if that doesn't work take it to your nearest apple store. - :)))
Calificación 0
reset network settings that fixed my issue.
Calificación 0
The voice mail 10 time on-off working with me thanks a lot
Calificación 0
Got this same issue and brought my phone to the apple store several hours ago. Tech can't resolve the issue so he gave me a new iPhone 6 plus but I found out after restoring from icloud that the problem still persists. Issue was resolved by resetting the phone again and not restoring from icloud but setting as a new iPhone. At last I could receive and place calls again by not pressing the speakerphone. Problem is I now have to install all my apps manually.
Calificación 0
Comentarios:
It's simple. Just clean your earphone port and the tiny speaker at the base. Anything could have blocked or interfered to deceive your phone that there is an earphone plugged in. I just solved mine now.
por
My issue is exactly like yours. I have tried 4 phones, and all exhibit the same problem once I restore from my backup. I don't care about the apps, but I cannot lose my contacts and other data. I have to imagine it is a combination of the newest ios update and carrier update, but cannot figure out how to downgrade them.
por
I switched on/off a few times, didn't work.
Thereafter I switched off, removed the SIM card, waited for a few seconds and put it back.
Now it is working. Hope it will stay!
Calificación 0
Hi there,
If the LCD is hot up the top as well,you would need to change the whole LCD incl earpiece etc...
Hope this helps
Calificación 0
Brake clean on a cue cleaned works fine now
Calificación 0
reset your phone. Issue was resolved by resetting the phone again and not restoring from icloud but setting as a new iPhone.
Calificación -2
Comentarios:
@lophez ,ever considered that copying other people's answer shows that you are lacking intelligence and good judgment?
por
Añadir tu respuesta
weareeachother estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 74
Últimos 7 Días: 570
Últimos 30 Días: 2,561
Todo El Tiempo: 473,396
