Broken 2013 logic board, upgrade to 2014?
My logic board on my MacBook Air 13" mid 2013 is damaged from coca cola spill :/
Can I change the 2013 logic board to 2014?
Es esta una buena pregunta?
Here's a listing of systems within this series: MacBookAir6,2.
As you can see there is a few Early '14 that you could swap out the logic board with. These logic boards are not cheap! You may end up being happier just buying a new system.
You still could have issues within the keyboard and trackpad from the spill. So think this through carefully.
Fue útil esta respuesta?
It works! Washed it with isopropanol :) Everything works!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 281
8 comentarios
Please give us the last four figures of your serial number (located on the back in very fine print), so we know your exact machine.
- de mayer
Or maybe I can downgrade to 2012? Cheaper...
- de Mike
Will mid2013 1,4ghz fit into this? I have mid2013 1,3ghz.
- de Mike
Cleaned all parts.
Well, now it starts... but stops again... will do the cleaning again.
https://www.youtube.com/watch?v=_hSYSUqT...
- de Mike
I can't speak for this specific Air. Some of the older ones had issues with using a different revision of the same LCD with the motherboard.
- de ABCellars
Mostrar 3 comentarios más
