Saltar al contenido principal
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
Preguntas 339 Ver todo
MacBook Air 13" mid 2012 will not power up
Hi All
My brother has given me his old MBA as it stopped working (would not power up) and went and bought himself a new one.
At first when I connected the charger the light flashed green constantly.
I opened the laptop to see if there was any immediate damage (water) but could not see anything.
I progressed to move the IO board which was clean and then the logic board.
The logic board had some debris around the Texas Instruments CD3210 area so I cleaned the board and re-assembled the laptop.
On reconnecting the Magsafe the indicator turned orange for a short while then (and ever since) has been a solid green, however the device will still not power up.
I have tried SMC reset. I'm confident that the keyboard etc is working fine and the magsafe light flashes during this process though still no sign of life from the MacBook.
I have also tried to bypass the power button but still nothing.
If I disconnect the battery the magsafe LED turns orange but again still does not power up.
The only possible thing I could think of is that my charger is not an official apple one.
Your help is more than appreciated.
Thanks
Darrell
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
Kits de Reparación de Batería de MacBook Air
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
1 Respuesta
Solución Elegida
Unplug the Mag-Safe adapter. Use a sponger or a toothpick and push the pins on the tip of the cord in and out several times to make sure they are completely extending. Check on the computer port to see if it is dirty or has anything in it. Give it another try.
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
Darrell Metcalfe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 359
