How fix loose charging port
Loose Charge port on Apple Mac Book Pro
Es esta una buena pregunta?
It sounds like the mounting screws internally have loosed up. But without some guidance on which model you have I can't offer you more.
Are you up to fixing your own system here? Do you have the needed tools? You may want to start there.
OK, Follow this IFIXIT guide: MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement upto Step 2, then look where the MagSafe connector is you should see two screws which holds the connector block (DC-In board).
If the screws are tight, then the whole DC-In Board unit will need to be replaced.
Follow the guide though or you may want to bring it to someone with better skills. This is a bit tricky repair as you need to fully remove the logic board to gain access to the DC-In Board connectors connection to the logic board is underneath.
Fue útil esta respuesta?
Here's a good source for tools: IFIXIT Store
Thanks for your response. Last three letters of serial number : 66D
I have no specific tools, apart from a few "Phillips" screwdrivers.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 10,696
2 comentarios
Can you give us the last four digits of your serial number so we can correctly identify which model you have.
- de Dan
2.26 GHz Core 2 Duo (P7550*)
Intro Date: June 8, 2009 Disc Date: April 13, 2010
Order No: MB990LL/A Model No: A1278 (EMC 2326*)
Subfamily: Mid-2009 13" Model ID: MacBookPro5,5
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 160 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
- de oldturkey03
