Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
How to drain gas tank?
craftsman riding mower, water in tank
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Comentarios:
A model number would help us help you.
- Por
917276844 that is the model number if you can help today id be really happy we need it runing
- Por
Agregar un comentario
Kits para Nintendo Switch
Una solución rápida para volver al juego
Comprar kits de Switch
2 Respuestas
Solución Elegida
Simple usually. Just look below the tank and before the carb. You should see a clear tube with fuel in it. It will have a pinch type collar on either end. Simply squeeze the tabs of the collar with a pliers,pull the hose free of it's male fitting and let drain into a bottle of some sort.
Fue útil esta respuesta?
Puntuación 3
Comentarios:
What if it don't have one of those tubes it has water in it we tried to drain it by putting the frount wheels in a skidsteer but results wasn't good
- Por
Here is a great video on how to do it safely: https://www.youtube.com/watch?v=zCA0Sw8h...
Whenever equipment is sitting unused over several seasons or especially several years, the gas should be drained as it can create a lot of costly damage to the motor.
Puntuación 1
Añadir tu respuesta
marlene estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 27
Ultimos 30 días: 89
Todo El Tiempo: 12,277
