Saltar al contenido principal
Repair and disassembly guides for GE Microwave ovens.
Preguntas 273 Ver todo
GE spacemaker microwave works intermittently?
Sometimes it works, sometimes it doesn't and occasionally will stop mid-operation. When it does stop midst cycle, there is a low hum, but no heat, no light, no turntable turning.
If the light does not go on when we open the door, the unit will not work.
We push on the turntable, push different buttons, open and close door....eventually it will start again.
Other times it starts right up like it should.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
This question was migrated from http://meta.ifixit.com/Answers.
por
Agregar un comentario
Kits de Reparación de Batería de MacBook Air
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
1 Respuesta
Solución Elegida
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don’t, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector
If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective.
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
anno estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 28
Últimos 30 Días: 68
Todo El Tiempo: 4,321
