Here is the translation from German to English using Google Translate starting at 2:41/5:09.
and glass and pull the wire from top to bottom. Here you have the wire
Moving from left to right, so when you were to tell her something. Caution should this Process
carry her to either second or so you should install your hair one
constant temperature of 80 degrees on the crystal arises
Then, when we have arrived at the bottom we removed the glass and put the home button
Next, we need to free the display from the adhesive. We use either
when the glue can easily remove our fingers and Rubein on the
Glue, but this should not be possible - as in this case - you harder
Guns ascend. I like to use isopropanol, a toothbrush and a Razor blade.
First of isopropanol on the display rub and let soak. Then with the
Razor blade the adhesive gradually dislodge. Warning, this process can be quite long
thumbs - works very slowly and carefully, so you do not zekratz the display or
even destroyed. If you are patient, it will pay off in the end.
After this, with a microfiber cloth for display glass degrease. Should you small scratches
have made pure, it is because we in the ON state, the scratches
Now we take the new glass, removing any protective film and stick the digitizer
on the tablet it again. I have used in the video the old glue, because it does not destroy
has been. You can of course also be a replacement part with new adhesive use
So now we constructed the tablet in the reverse order of removal.
the model is sm t320
- de sophie
