Is there a way to replace the camera on the display?
Whenever I open Photo Booth or Skype, my MacBook says no camera can be found. Is there a way to replace the camera or check if a cable came loose on the motherboard?
Es esta una buena pregunta?
I've never seen the actual camera go bad. Most likely is a bad cable connection. Check step 6 of this tear down to make sure it's plugged in correctly. This is an easy fix. MacBook Pro de 15 pulgadas Unibody de finales de 2008 y principios de 2009
Fue útil esta respuesta?
Well since it's a unibody you have to remove the entire display assembly.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 493
