Saltar al contenido principal
Remove CD from iBook that won't power up?
How can I remove a CD from an iBook that does not power up?
Contestar esta pregunta I have this problem too
Puntuación 1
Añadir un comentario
Kits de Reparación de Android
Estás a un kit de tu nueva pantalla o batería.
Comprar Ahora
Comprar Ahora
2 Respuestas
Most Helpful Answer
Remove the optical drive and open it up. Here's how to do it:
iBook G4 12" 1.33 GHz Optical Drive Replacement
¿Ha sido útil esta respuesta?
Puntuación 1
Comentarios:
No, tape did not work. I tore the iPod apart and got the disc out.
by
Try holding the trackpad down at power on - the disk should eject.
If that fails try the double sticky tape method:
  1. Get an old CD/DVD and some thin double sticky tape (like scotch tape ~3/4in wide).
  2. Put a couple of strips close together on one edge of the CD/DVD,
  3. Firmly hang on to the CD/DVD and angling the disk put it part way into the slot TAPE SIDE DOWN.
  4. Rotate the disk flat. (You want to try to snag the disc with the tape, so that you can pull it out)
If that doesn't work time for mayer's solution.
If this answer is acceptable please remember to return and mark it.
Puntuación 1
Add your answer
Edward will be eternally grateful.
Ver Estadísticas:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
Global: 138
