U601 RF Replacement iPhone 5 Baseband Chip IC U16X
Hi,
I have a problem with an iPhone 5 it was dropped and has had a new front panel but the phone is now not activating, the phone has been restored and now gets Error 16 about 80% through. After some research I found its probably the U601_RF. I have purchased this http://www.ebay.co.uk/itm/291322189388?_... as an attempted fix but I need some advice on removing the original chip.
I have removed the EMI Shield from the mainboard using a heat-tool with a 4mm tip @ 250 degrees, but this doesn't seem to be enough for the chip as its not budging. I have cranked the temperature up a bit to 300 but still not moving. I dont want to go above this temp for obvious reasons. Can anyone offer any advice on removing the chip without damaging the mainboard? I think there may be some resin surrounding the chip but its pretty hard to see, maybe this needs cleaning/removing first?
Thanks
Es esta una buena pregunta?
3 comentarios
Have the same problem. Also bought that chip in ebay and don't know how to replace it. Please give me update once you already fixed yours. Thanks.
- de ronnramos
you have to use a hotair Station. the Temperatur is min 345 - 350 °C to desolder an ic in the iphones. The solder is lead free!
- de web
Hey guys did the baseband chip did solve your problem? And do you know an adress where we can send the iPhone's to be repaired if so?
- de tregouetsylvain
