No service problem iPhone 4
Hi
I have problem no service
I change SIM card and anything change
I also change cellular antenna
What can be the problem
Thanks
Es esta una buena pregunta?
Hi
Thanks
If you're in your carrier's coverage area
Follow these steps, testing after each.
Tap Settings > Enable Airplane Mode, wait five seconds, then turn off airplane mode.
Restart your device.
Remove the SIM card. If the SIM card is damaged, worn, or bent, or if it's too big or small for the SIM tray, contact your carrier for a new one. Then reinsert the SIM card.
Check for a carrier-settings update: Connect to a Wi-Fi network, tap Settings > General > About, and install any available carrier-settings updates. If you can't connect to Wi-Fi, connect your device to a computer that has iTunes.
Update your iPhone to the latest version of iOS.
Reset network settings by tapping Settings > General > Reset > Reset Network Settings. This will reset all network settings, including Bluetooth pairing records, Wi-Fi passwords, VPN, and APN settings.
Contact your carrier to check for any network or account issues.
Restore your iPhone.
If you see No Service while roaming or traveling
You might be outside of your carrier's coverage area. If you're traveling internationally, you'll need an international roaming plan to use your iPhone or iPad.
Fue útil esta respuesta?
"Reset network settings by tapping Settings > General > Reset > Reset Network Settings." worked for me :)
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,949
