Wow these are some misleading amature Repair answer on this forum. Unless you are a certified tech or have many years actaully Repairs not replacing parts, shouldn't answer. I do motherboard work and I've never had a tv issue that isn't fixable . the only way I've ever replaced the whole LCD Screen itself is if it's completly shattered. I then still pull it apart , =Repair any damages backlights , resolder chips, replace ribbions and etc. Finding a compatible front glass of the layers of the screen can get tricky but it's all just a matter of proper research , self confidence and dedication. If not tech savy with a solder gun or ever messed with a board have a tech savvy buddy lend a ✋ . ///dpluda563@***gmail///.\\\com\\\ all one word no symbols I use to avoid spam . need help feel free to message I'll do best to lead you in the right direction.
5 comentarios
Could be TAB (would most likely require a new LCD) as well as a t-con board issue. Post an image with your question so we can see what you see.
- de oldturkey03
I have 2 Vizo Tvs Both went out in 2 years period . I would love y
Too have them fixed but paid a lot for them 65in and a 45in Went back too store to see what kind of Warrenty they had none ...and 2 years and Over 2,000 Gone...
- de ctate
I insured my Vizio E-series 50 inch 3D TV for $8. When mine went, They replaced my TV with a Samsung HDTV. There were NO Vizio 3D TVs available, and other 3D TVs were $1800 dollars MORE for 3D. They said: "You can do whatever you want with the broken TV. I kept it. I have now done all the research, and have purchased the necessary parts. I will now FIX that puppy.
- de Sniperbait66 RVN
Just got a Vizio 55" smart tv have had it less then a week and lines through the picture when using YouTube. They stay even when I back out to regular tv and have to shut off tv to get rid if them.
- de Linc-a-tic77
I'm having a similar issue with a vizio sv470m. When I go to turn it on, the tv will have horizontal lines. Eventually it ends up working correctly. I just play with the buttons or unplug the power for certain amounts of time. After I get the tv working, as long as its on there are no issues with it whatsoever. Now if these simple methods don't work, ive heard it may be issue with the ribbon that connects between the board to the screen and the other board. I'm not being specific because on my model it look like the display board goes to the power board. I'm guessing its both the tcon and power board.
- de Cyrus Cattani
