Saltar al contenido principal
Modelo M2453 o M6411 / 300, procesador 363 o 466 MHz G3
Preguntas 66 Ver todo
How to install a backlight
How to install a Backlight
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
Is the backlight completely off or is it dim ??
there are a few possible problems with the backlight
1, the ccfl backlight failed - it would be easier to replace the whole lcd
2, the inverter died - replace the inverter (but sometimes a "new" (used) display assembly is cheaper
3, the inverter cable is scuffed - replace the inverter cable (search on ebay)
4, the inverter cable socket is loose - resolder it/find someone who can resolder it for you (in case you are not able to do that)
since the clamshells are sometimes pretty cheap to find on ebay - i would search there (got my blueberry clamshell for ~30$)
Fue útil esta respuesta?
Puntuación 3
Comentarios:
+ for the acceptance
- de
Añadir tu respuesta
bjluchion estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,637
