Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 3305 Ver todo
iPhone 4: Black Screen and "bong" Tone/Noise
I tried to follow the tutorial to repair my iPhone 4's home button. Unfortunately the process was a failure because I am now experiencing a black screen and a never ending "bong" noise when plugged into a wall outlet.
Can anyone help/provide insight as to what's happened to it and if you think I can fix this, or should I just junk it for parts/repair on ebay? I don't know if this means the logic board has failed...
https://www.youtube.com/watch?v=BR9B-Fye...
Edit: I gave up. I took the whole thing apart and and tried to reassemble and the same thing occurrs. Not worth fixing this phone ($40 for a display really?) so I will be putting it on ebay for parts or repair.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Open back up and make sure the screen connecrors are fully pressed down and seeded correctly if still the same after that you will need to try a new screen.
Fue útil esta respuesta?
Puntuación 0
Comentarios:
Thanks for your response. They are definitely seated correctly - I've reseated them a few times now trying to resolve this (probably only making my chances of getting this to work even worse). So do you think that I destroyed the LCD screen cable? I was pretty careful while I did it and there is no visible damage ie like a cut or hanging cable, so I'm pretty disappointed...
- de
Try to do a hard reset on the phone... holding home button and power button at the same time.
Puntuación 0
Comentarios:
Didn't work, unfortunately.
- de
Añadir tu respuesta
John Cuppi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 289
