SSD + HDD setups installed new HDD but it wont work
Just installed a new HDD, upgraded from 500gb to 1tb I used the WD scorpio blue but now it wont allow me to create folders or transfer files (BTW this is in my optical drive slot) I cant even do an erase on disk utility "couldn't unmount disk" but when I removed it and installed it on an HDD enclosure I was able to do a reformat
What would be the problem the caddy or the sata cable? or any other solutions that I forgot to make when I installed the new HDD?
Update
Im using yosemite my my sdd contains the apps and my hdd contains the media files I did not reformat the hdd just my newly installed hdd, Im using a generic caddy.
Es esta una buena pregunta?
1 comentario
Bluerthanlou - Did you read the OWC note I pointed to you? The issue has nothing to do with the carrier but the drives inability to talk to the system at the needed SATA speed though the carrier. You will need to get a fixed speed SATA II drive to put in your optical drive carrier.
- de Dan
