Saltar al contenido principal
Este Power Mac G4 tiene puertas de unidad de espejo.
Preguntas 80 Ver todo
Pregunta Cerrada
What is the best method of removing scratches from the case?
I have purchased a PowerMac3,6, (MMD G4). The tower's case (not the doors) has a number of fine scratches, some are deeper than others. What is the best method to buff out these scratches while keeping the case's mirror-smooth finish?
Thank you,
Es esta una buena pregunta?
Puntuación 0
1 comentario
Wil, are we talking about the Acrylic sides?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Wil, fine scratches can be removed with a mild abrasive polish such as Novus #2, or Novus #3. Heavier scratches, such that you can feel with your fingernail, will require some elbow effort to remove with a bit of sanding and buffing. A series of grits (150,400,800) followed by a buffing wheel and available buffing compound, this should restore your case. Check on here to get an idea of how its done. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thank you. That is more or less what I was thinking.
- de
Respuesta Más Útil
I would honestly just get a new case, they are not that hard to instal if the scratches are that bad. If they are not some Pledge works great.
Please mark me up if this helps : )
Puntuación 2
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 787
